11-07-2018
14:35
09:23
AlejandraFitbit
11-07-2018
14:35
09:23
AlejandraFitbit
Hi all hoping someone can help me... got my Fitbit Versa as a present and I was changing the strap earlier and now it won't turn on. All that is coming up on the screen is a red triangle with an exclamation mark in it. I tried a factory reset and although the Fitbit logo comes up for a second it disappears really quickly. Has anyone had this issue or can offer advice? Thanks in advance!
Moderator edit: subject and format
Best Answer11-08-2018 01:38
11-08-2018 01:38
Have you tried restarting restarting your Versa. You can do this by pressing and holding the left button and bottom right button together for 15 secs.
11-09-2018
09:25
08:06
11-09-2018
09:25
08:06
Welcome to the Community @Walsh1988 and @N8teGee thanks for the input.
I would like to know if the instructions provided by our friend worked? Had your watch start working after the restart process?
Hope to hear from you soon. ![]()
Best Answer01-25-2019 12:23
01-25-2019 12:23
Exact same error with my Ionic last night. Will not reset with the two or all-three button attempts. I called support, but they were not able to help. Please let me know if there is a solution. Thanks.
