11-19-2018 19:12
11-19-2018 19:12
My versa will not turn on. I tried the restart and charging it, but it doesn't do anything! I just got it maybe three months ago! Help please.
Best Answer11-19-2018 21:40
11-19-2018 21:40
I have the similar problem with my Fitbit Versa device. I bought mine mid-September this year. Can someone please help us.
07:37
- last edited
yesterday
11-20-2018
07:37
- last edited
yesterday
Hey guys, I hope you are doin' fine!
@Versavested, have you tried to restart your Versa? If you haven't, please follow the steps in this post to do so.
@Caleenoel, I appreciate the tips you have tried so far to make your Versa work. Let me ask you this, when you plug it into the charging cable, is the screen completely blank? Have you tried to charge it with a wall adapter instead of your computer?
Let me know how it goes guys!
11-20-2018 09:30
11-20-2018 09:30
@Caleenoel, Yes I have tried to switch it off and on multiple times, and yes I charge it from the wall plug, not from the laptop....still nothing😏😏😏
Best Answer11-20-2018 20:36
11-20-2018 20:36
@Versavested @Caleenoel Try performing factory reset using 3 buttons:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
11-20-2018 22:01
11-20-2018 22:01
@Marrrmaduke, mine has gone blank. I've tried EVERYTHING I can. I'm taking it back unfortunately. Let them sort it out.
Best Answer11-20-2018 22:09
11-20-2018 22:09
@Versavested I agree. This might be a hardware issue. Good luck.
11-23-2018
07:52
- last edited
yesterday
11-23-2018
07:52
- last edited
yesterday
Thanks for taking the time to try the instructions that were posted along this thread @Versavested! I'm sorry to read that they didn't work. If you have decided to get a new Versa, and have further questions about it, let me know. 😉
Thanks for your help @Marrrmaduke!
I'll be around!
