06-25-2020
06:30
05:03
06-25-2020
06:30
05:03
my fitbit versa is showing the fitbit logo on its screen while charging,but vanishes once it's off charger.still can't switch it on after 5 hours of charge.How to resolve it??
06-26-2020 05:05 - edited 06-12-2024 05:04
Hello there @sourav2k4, welcome to the Community Forums. Thanks for the details provided about your Versa's behavior, I'll be glad to help you.
If you haven't done so yet, I'd recommend restarting your Versa as described here: How do I restart my Fitbit device?
If the restart does not work, please try the steps below:
Best Answer06-26-2020 05:13
06-26-2020 05:13
I'm having the same problem, black screen won't turn on.
Best Answer06-26-2020 06:54 - edited 06-12-2024 05:04
Hello there @SunsetRunner, welcome on board. To better assist you with your Versa's screen issue, would you mind taking a look at my post above and try the suggestions I provided? If that doesn't work, let me know so I move forward to the next step.
Keep me posted.
00:54
03:17
06-29-2020
00:54
03:17
Hello,
I tried everything that had been suggested,but unfortunately nothing seems
to have worked out .Please look into it.
Moderator Edit: Personal info removed
Best Answer06-29-2020 03:20 - edited 10-12-2023 02:50
Hi there @sourav2k4, I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
