03-25-2020 11:12
03-25-2020 11:12
Does the Versa2 have the ability to receive Microsoft Teams notifications?
04-16-2020 08:40
04-16-2020 08:40
Go to your notifications settings under the Charge 4 / Tap App Notifications.
Then find the apps you want to receive notifications from and place a check mark to the right.
03-26-2020 08:03
03-26-2020 08:03
Is Microsoft teams have an app for the phone?
If so then the user only needs to add the app to the list for notifications.
04-16-2020 04:59 - edited 04-16-2020 05:01
I'm wondering the same thing. There isn't a Teams app. Any updates or workarounds?
Best Answer04-16-2020 05:07
04-16-2020 05:07
Any notifications that appear on your phone can appear on your Versa. Go into the Fitbit app, select your device and select Notifications, then just turn on or off which ones you prefer.
04-16-2020 05:16
04-16-2020 05:16
@203tom if your reffering to an app that is on your phone, and if this app has the ability to send notifications popups while the phone is locked. Then yes, the app in question will be able to send notifications to your Versa 2.
So as long as the app you want notifications from is on the phone you can get notifications on the Versa 2
04-16-2020 05:20
04-16-2020 05:20
I'd be interested in using a Teams app that was developed for the Versa 2, and I'm curious how functional that might be. But right now, I'm just looking for notifications. Thank you
Best Answer04-16-2020 05:42
04-16-2020 05:42
I have the Teams app on my iPhone, not sure if it’s available for other phones.
I haven’t gotten the Versa2 yet but once I do, I’ll try to remember to update 🙂
04-16-2020 05:46 - edited 04-16-2020 05:47
Hi, I have the Teams app (Android). It might be nice if there was a Fitbit Teams app. Can you respond to Teams notifications? Right now I have Teams open on my desktop as well as my Android. I can see that I'm getting notifications. However, they aren't showing up on my watch. I'm thinking I did something wrong when adjusting the notifications settings or there is a lag.
Best Answer04-16-2020 08:40
04-16-2020 08:40
04-16-2020 08:43
04-16-2020 08:43
It's working. Thanks. My phone was on do not disturb
