Go to your notifications settings under the Charge 4 / Tap App Notifications.
Then find the apps you want to receive notifications from and place a check mark to the right.
Any notifications that appear on your phone can appear on your Versa. Go into the Fitbit app, select your device and select Notifications, then just turn on or off which ones you prefer.
@203tom if your reffering to an app that is on your phone, and if this app has the ability to send notifications popups while the phone is locked. Then yes, the app in question will be able to send notifications to your Versa 2.
So as long as the app you want notifications from is on the phone you can get notifications on the Versa 2
I'd be interested in using a Teams app that was developed for the Versa 2, and I'm curious how functional that might be. But right now, I'm just looking for notifications. Thank you
Best AnswerHi, I have the Teams app (Android). It might be nice if there was a Fitbit Teams app. Can you respond to Teams notifications? Right now I have Teams open on my desktop as well as my Android. I can see that I'm getting notifications. However, they aren't showing up on my watch. I'm thinking I did something wrong when adjusting the notifications settings or there is a lag.
Best AnswerGo to your notifications settings under the Charge 4 / Tap App Notifications.
