06-11-2019
17:32
10:08
JuanJoFitbit
06-11-2019
17:32
10:08
JuanJoFitbit
3-4 times tonight my versa has turned off. I put it on the charger and it comes back on with over 50% battery. It is about 6 months old.
Moderator edit: format
Try restarting it several times. If it still happens following this, then try a factory reset (settings app and scroll down to About) If that doesnt fix it then olease come back here.
Helen | Western Australia
@Alisross welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it turns off all of a sudden.
I'd like to know if the issue persists or if it got resolved after following the steps that shared @NellyG.
If you found her post helpful, please accept it as a solution so other users that experience the same issue can find it easier.
Looking forward to your response! ![]()
