Hi @Happyvv - if you mean battery % it's on the left in the V4 Fitbit App or on the right when you pull down to sync in older versions.
It will only be accurate if the watch has properly synced.
You can see it on the watch too with a pull down, at the top, or by using a clock face that's shows.
Best Answer@Happyvv My Dutch to English translator says you are asking about your body fat percentage. I use an lPhone and I see a list of my recent data (weight and body fat) when I tap on my weight tile. I have graphs at the top of my screen and can see a body fat graph when I swipe left on the graphs. I use an Aria 2. You might need to do something differently if you use a different brand of scale.
Laurie | Maryland
