07-28-2022
23:00
17:44
07-28-2022
23:00
17:44
I resently switched from versa 2 to versa 3, the old one stop working 😞
I have the vibration on the strongest setting, but i can only feel it if i touch the sides with the other hand or have the face touching a table, or someting like that.
Can i do anything to make it better?
I am afraid that i won't wake from the alarm, worked fine for me with versa 2
07-29-2022 01:45
07-29-2022 01:45
Hi @Carohline - weak vibration on the Versa 3 and Sense is a known issue, especially if you are used to a Versa or Versa 2 which had good vibrations [ Beach Boys note!].
Putting it on Strong and keeping the battery charged is all you can do, as it gets even weaker as the battery level falls.
There are 8 main vibration types and if you want to test them try the SimpleVibrate app.
