01-24-2019 14:04
01-24-2019 14:04
My wireless headphones work properly with my Fitbit versa but the volume doesn’t work. When am listening to music I can not control the volume from my Fitbit
02-01-2019 13:13
02-01-2019 13:13
@Jelilah Remove the buds from your phone's Paired Devices list and turn off Bluetooth on your phone. Now reboot Versa (press and hold the left and bottom right buttons until Fitbit logo flashes), reset your buds according to manufacturer's instructions and put them in a pairing mode. Try connecting to Versa again.
01-24-2019 22:56
01-24-2019 22:56
@Jelilah by any chance do you have apples airpods? Known issue with those.
01-25-2019 05:04 - last edited on 03-09-2020 16:10 by LiliyaFitbit
No just normal wireless sets
01-25-2019 17:33
01-25-2019 17:33
@Jelilah whats the model and who's the maker? Have you tried searching the forum if anyone reported issues?
02-01-2019 03:18
02-01-2019 03:18
I7 tws wireless headphones
02-01-2019 13:13
02-01-2019 13:13
07-31-2019 06:11
07-31-2019 06:11
My problem is the volume control. The AirPods work but no amount of attempting to adjust upward works.
09-04-2019 14:02
09-04-2019 14:02
Hello! I have the same pair of devices as you!! Did you solve the volume problem? I have the same problem and i can’t fixed it!
09-04-2019 14:19 - last edited on 03-09-2020 16:10 by LiliyaFitbit
I succeeded in getting some music downloaded to play at an acceptable volume but its uneven. Some selections are fine, others softer, and there seems nothing on the device to control volume. A friend, not a Fitbit user, suggested the problem may be related to how some of the music was purchased, whether from Apple iTunes or not.
03-03-2020 10:57
03-03-2020 10:57
i have the i9 s and i cannot control the volume
01-01-2022 17:29
01-01-2022 17:29
has this ever been fixed? i got a versa 2 and i have airpod pros and everything seems to work except volume control so it blasts in my ears. there are 2 buttons that resemble the + and - sign which i assume are supposed to control volume but when i tap them repeatedly the volume doesnt change
01-08-2022 16:30
01-08-2022 16:30
Benjamincaprig,
did you ever fix your volume problem? I have Bluetooth headphones connected to versa 2 working fine using the volume controls on the earbuds (tapping) but would like to use the + and - icons also on the music controls of the Versa 2.
Any ideas?
My headphones are:Tiksounds Wireless Earbuds, Bluetooth Headphones
03-23-2022 10:04
03-23-2022 10:04
I tried this but it didn't work. Has anyone figured out how to control the volume on Versa 2? It is blasting my eardrums.
