06-04-2018 03:19
06-04-2018 03:19
Has anyone noticed that some of the watch faces are really slow. Especially after you swipe up to check today’s data, then you press the button on the left to return to the watch face. It can be really slow / delayed about 5 seconds. It’s really annoying because it makes look like an old computer ten years ago. Anyone has the the same problem?
Best Answer06-04-2018 03:35
06-04-2018 03:35
I tried and mine takes 2 seconds roughly.
do you have lots of apps installed ?
any music stored ?
I also restart my device once a week roughly .
so far no issues to report.
using versa with galaxy s8
Best Answer06-05-2018 00:11
06-05-2018 00:11
I tried to restart my versa but the problem remains. I’ve tested many watch faces and I found that for those very simple faces took about 2 seconds. But for those with more features or animations like ‘my cat inca’ or ‘img’, it literally took 5 seconds. And it not only happens when you switch back from today’s data but also when you finish using the apps and swipe back to the watch face. I have 17 apps in total. Thanks for the reply by the way.
