12-23-2018 13:48
12-23-2018 13:48
For the past couple of weeks the weather app doesn’t seem to be working on my versa. It says to sync with my mobile app which I’ve done several times but no change...anyone experiencing the same issue or have a fix for this?
Best Answer12-23-2018 14:27
12-23-2018 14:27
Hi, this has become a well known issue. Are you still using the old or the newest .30 Firmware. What works for me in both version is the following:
1. Go to the weather app and press the settings icon on the right side of the screen
2. Once your there, you will see the locations that are present in the app. Mostly it only says "Current Location".
3. Leave it there, but press Add location and enter the exact data of your location manually. when everything goes well, you will see your exact location added to the list, if not choose one that is very near to your own location (not all locations are found).
4. Restart your phone and sync it with your Versa and, as it does for me already for a long time, the weather will be updated on your Versa.
Best Answer12-24-2018 15:25
12-24-2018 15:25
Restarted my phone and it worked. Annoying.
