Weather tile
My first weather tile is displaying Manchester. How do I remove it? I've tried having only current location enabled, synched it and it's still there.
2 REPLIES 2
Hi, go to the weather app in My apps in your Firbit app, on the right side of it you will see the settings icon. Press that and you, when everything is working as it should, see My current location and, in your case, Manchester. Press and hold Manchester unill you see on top of the screen the garbage icon and you will be able to remove it.
Manchester is not listed. Even when I choose to use My current location (w no cities listed) it still shows Manchester weather and nothing for My current location.
