Weather won't sync to my Versa
ANSWERED
Weather won't stay synced
1 BEST ANSWER
Accepted Solutions
Hi there @suzwaring, welcome to the Community Forums. I'm sorry to hear that Weather app isn't syncing to your Versa, I'll be glad to help you with this.
If the weather doesn't update, check the following settings:
  • Location services must be turned on for the Fitbit app. For instructions, see How do I use GPS on my Fitbit device?
  • The Fitbit app must remain running in the background on your phone.
If you change locations, sync your device to see your new location in the Weather app.
On a side note, please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher, Android OS 7.0 or higher, and Windows 10 version 1607.0 or higher. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit app, and are constantly working to confirm compatibility with new phone models. Be sure to verify that your phone or tablet meets the minimum operating system requirements.
1 REPLY 1
