01-05-2019 11:19
01-05-2019 11:19
Just got my versa appenently it doesn't get whatsapp call notifications.
When this will be fixed?
I used to receive whatsapp call notications on my alta
01-05-2019 11:25
01-05-2019 11:25
Hi, in order to receive Whatsapp notifications, you will need to activate it in the Notifications: Go to Noticications - App Notifications - Scroll down all the way untill you see Whatsapp and click the empty square right nect to Whatsapp and it will be activated. Good luck!
Best Answer01-05-2019 11:30
01-05-2019 11:30
Best Answer01-05-2019 11:38
01-05-2019 11:38
Hi, AFAIK you will only get the messages and not the calls from within Whatsapp and do not know if a Whatsapp call is noticed as such by enableb calls. Regarding the vibration: go back to notifications - scroll down untill you see "Settings for Vibrating" and enable it.
Best Answer04-17-2019 03:43
04-17-2019 03:43
Still nothing ...
Best Answer04-18-2019 10:33
04-18-2019 10:33
Any ideas?
Best Answer04-18-2019 10:35
04-18-2019 10:35
01-06-2020 08:24 - edited 01-06-2020 09:17
I used to have an Alta as well and would receive notifications for Whatsapp calls.
I've gotten an Inspire HR expected the same functionality, but I'm only able to get Whatsapp message notifications, not calls. I'd like to receive call notifications but not message notifications.
Please please make this available again! I'd make a feature request but I doubt anything will be done about it.
