04-22-2018 07:18
04-22-2018 07:18
In the 7 preset exercises on the watch, walk and hike are not options? I walk or hike mostly so if I want accurate results I have to use the phone app. Then, I can't monitor my progress on my wrist. It seems pointless to have the watch. If I use the watch in "run" mode, I get ridiculously under accurate results with the GPS.
04-22-2018 07:23
04-22-2018 07:23
Press the upper right hand button on the dashboard of the Fitbit app. Click on the Versa button. Scroll down to the exercise shortcuts and click on them. Click the edit button to delete one of the seven exercises you won’t use. Click on the add button to get to the other right exercise choices to add which one you want .
04-22-2018 07:23
04-22-2018 07:23
04-22-2018 11:10
04-22-2018 11:10
Guess I missed that part in the instructions. Thanks.
08-29-2018 21:14
08-29-2018 21:14
there is no walk option there anymore
08-29-2018 23:19 - edited 08-29-2018 23:20
There is no edit buttom in the exercise Shortcuts.
I have all 7 in use and can not switch to walk.
Update: You need to swipe to the left on any shortcute and than you get the edit buttom.
01-21-2019 14:06
01-21-2019 14:06
Thank you!
01-23-2019 19:42
01-23-2019 19:42
Thank you! That was an easy and quick fix. 🤗
01-24-2019 04:31
01-24-2019 04:31
Yes, you can’t add it as an option, there are also lots of other options.
10-17-2019 15:02 - edited 10-17-2019 15:07
This kinda upsets me!!! Walk was the only one I used!!
I have a new Versa 2.
10-17-2019 15:05
10-17-2019 15:05
There seems to be just 7. And no way to edit or delete any. ???
11-24-2019 11:43
11-24-2019 11:43
On my versa it was the upper left hand button on the app.
After that the instructions worked.
Maybe it changed with an update?
Thanks
