01-30-2020 08:17
01-30-2020 08:17
I recorded my workout this AM but its not showing up on my dashboard nor under activity for today. Is there a lapse of time before it syncs? I've successfully saved past workouts and ended the session the same way, so I'm confused. Thanks.
02-05-2020 15:50
02-05-2020 15:50
@LCMemphis Welcome to the Community. Sorry for the delayed reply.
Thanks for the details mentioned and the troubleshooting tried.
Your workouts should transfer to your Dashboard as soon as you sync your Versa 2. I would like you to make sure you're doing this procedure to track your activity.
If you did but your activity isn't showing, please try the tips mentioned in this article: How do I add, edit, or delete Fitbit data and activities? Could you let me know if you tracked the activity using SmartTrack or the exercise app?
Keep me posted. I'll be around if you have any additional questions.
02-05-2020 16:21
02-05-2020 16:21
Thanks...I don't think my versa 2 is synced. Also, can I look at past workouts on my watch or do i need to go to Dashboard App on my phone?
Best Answer02-07-2020 16:41
02-07-2020 16:41
@LCMemphis It's nice to see you on the Community.
Based in what you mentioned your Versa 2 is paired to your account, check this article to learn more about how Fitbit sync their data?
In order to see your workouts and data tracked by your Versa 2, you will need to sync and then check this information on your app or Dashboard.
