01-17-2019 17:03
01-17-2019 17:03
Guys, whenever I sync my versa with my IPad, it keeps restarting. Got any tips? Anything to do with the apps I installed? Please help!
Best Answer01-17-2019 19:38
01-17-2019 19:38
@JSpider does it only happen when you sync with ipad or other devices as well?
Best Answer01-18-2019 14:17
01-18-2019 14:17
Best Answer01-18-2019 21:24
01-18-2019 21:24
@JSpider Before I recommend a factory reset, please try the following:
Try this procedure to see if the sync can be restored and Versa stops rebooting. If not, restore your tracker to factory defaults as indeed this can be related to 3rd party apps. Restoring the tracker to factory defaults will wipe it, so it would be good if you could sync first. I understand you may not be able to. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your iPad's Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Good luck!
Best Answer01-21-2019 13:27
01-21-2019 13:27
Thanks! I recently heard someone say that it is a bug, and later it will be fixed in future updates. If that does not work, then I will follow the procedures you gave me above. Thank You!
