09-25-2022
12:25
17:09
09-25-2022
12:25
17:09
Looking for a way to turn off the x2 minutes in the zones. All I want is to know how many minutes I spend in each zone, without it being double.
Hi @Torchwood - this isn't possible normally, as it is supposed give a better representation of activities compared with the original active minutes.
You can play about with custom heart rates but that messes up things, because it can't show when you are in the zones correctly.
You can try clock faces from the gallery which show active minutes, such as SimpleClockPro which can give you both active minutes and active zone minutes.
Best AnswerI will give the SimpleClockPro a try, thank you for that suggestion.
I don't doubt that the zone system gives a better overall look at things, but what I want to see is how long my heart was in the cardio zone without having to divide and guess.
For example, yesterday, I had 106 zone minutes, 1x 14 minutes of fat burn, and 2x 92 cardio and peak. So my guess is 46 minutes in the zone I want. Maybe.
I get they have a gimmick people like; I just want the option to avoid said gimmick should I choose to.
Rant over, off to try SimpleClockPro.
Thank you!
