03-02-2019 01:26
03-02-2019 01:26
Hi,
i have using a fitibit versa fore 2 months now but he stops synchronize.
I dit a complet reset of de fitbit and the fitbit app.
When i wanne make e new connection the app says he finds the fitbit versa but doesn't get any connection.
What else can i try?
Or do i have to get my fitbit to the store?
Thanks,
Anouk
03-02-2019 09:03
03-02-2019 09:03
Hi, the reason for not connecting to your phone is the Factory Reset procedure. This brings your Versa back to the "in the box" state and as such acts like a new watch. You will need to do the entire setup with your phone all over again. Hope this helps.
