07-20-2018
17:28
06:53
HeydyF
07-20-2018
17:28
06:53
HeydyF
I’ve discovered a problem where my Versa won’t sync with my iPhone 7s. It only happens when I use my Bluetooth headset but once I do I can’t sync the versa with the iPhone app until I do a factory reset.
if I have my Versa paired and the iPhone app open and syncing prior to using my Bluetooth headset the problem won’t happen. But once I forget and pair my headset without the Fitbit iPhone app open and paired I’m screwed and have to factory reset the versa or I can’t sync.
I'm working with tech support but they haven’t come up with a solution so maybe the forums will shed some light on the problem.
Moderator edit: Subject for clarity and format
I just recently just started using the Versa. I'm going to hook up my Fitbit Flyer headset and see if this happens.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
07-21-2018
06:52
06:20
07-21-2018
06:52
06:20
Hey @MarkeG40, welcome to the Fitbit forums! Sounds pretty weird that your Versa only syncs with the Fitbit app after you factory reset it. But don't you worry, I don't know if you already tried this out with our Support team, but if you haven't, I'd like you to follow these tips to properly sync your watch:
If your device still won't sync, try these steps:
@ACG, I will appreciate the update my friend!
Let me know how it goes guys!
Thanks for the replies. I tried all those steps and still the versa will only sync after a factory reset and then only until my phone connects to a Bluetooth device with something other than the versa.
I have spoken with with tech support and they are replacing the versa.
05:25
06:20
07-23-2018
05:25
06:20
I appreciate the time you have taken to try to fix this syncing issue with your Versa and your iPhone 7 @MarkeG40. On the other hand, sounds great that our Support team has helped you out with this and have determined that replacing your Versa was the best decision.
If you have further questions or comments, let me know!
