Sounds to me like you need to install it into the app as a new device and set it up?That, or it is stuck and you need to do a restart by pressing the left back button and the right lower button at the same time while holding for less than 10 seconds. Then try setting up again. Good luck!
Best Answeri did uninstall and reinstall still no notifications, im also trying to download the bluetooth and pandora app.
