05-14-2019 07:32
05-14-2019 07:32
Hello everyone .. I bought the watch yesterday used maybe for 25 min and the computer numbers are not the same as the watch... I put it on two hours ago and it says that I have already given 2,465 steps on the initial screen ..... how i can reset the watch bc those numbers are not real.. I now im a little bit disappointment bc IDK if the information is going to be real. How I can change the weather app to a Fahrenheit instead of Celsius.. Thanks. Versa Lite
Best Answer05-19-2019 13:34
05-19-2019 13:34
Hi, regarding the number, although it's a new watch. try this. Regarding the weather unit: press in the dashboard the watch icon and you'll see the page with the Clock an App tiles. Press Apps, My apps are default shown. Scroll down untill you see the Weather app and press the setttings icon right next to it. You will get the page where it says "Temperature Unit", press "Unit" directly underneath it and you can change it to Fahrenheit instead of Celsius.
