05-19-2019 06:29
05-19-2019 06:29
Check that you don't have 'Notifications' turned off. Hold in left button a few seconds. Look for 'Notifications' under 'Screen Wake'. Tapping that toggles notifications on or off. If you have a credit card entered, you might have to scroll right or left to get to that screen.
Best Answer05-19-2019 07:21
05-19-2019 07:21
Also be sure you have enabled notifications in the Fitbit app. You have to set a default app for calls, texts, and calendars. From the app, you can also set other app notifications if your device supports it.
Best Answer05-19-2019 13:06
05-19-2019 13:06
@Carolyn61 have you tried the suggestions? are you up and running now?
Elena | Pennsylvania
