Currently I get a notification when my sense is at about 25% low battery. However I would like to have it notify me around 10% when it is more "critically low"
Hi @Misskama87, thanks for taking the time to share this product feedback about being able to customize the % level for the low battery notifications with us. I noticed this product feedback was already requested in this board, so I’ve moved your post here. Please support this product feedback idea by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
I got the Sense 2 and I get notification when I still have 35% battery level. Normally, with my old fitbit, getting this notification means I should charge the tracker the next chance I can, most likely, that means before the end of day. But being at 35%, I still have almost a day of usage before it falls to the so called critical 20% where it is bad for the battery to fall under. If I wait until the next day, I most likely will forget because the notification alert disappears once I use the app (can't keep it persistent).
So either have the Sense 2's low battery notification be set to lower, have the tracker have multiple levels of notification, or have reminder alerts every 12 hours so we won't forget to charge the tracker if we don't rush to the charger as soon as the notification appears.
I'd like the option to set the Battery Level percentage at which I'm notified. I receive the Battery Level Low notification too late, but some would prefer to receive it at lower percentages. If away from home, I may not have time to reach the charger before it dies. If the notification comes at night and I don't see it, the fitbit dies overnight.
Hi @Dittodivine, thanks for taking the time to share this product feedback about choosing the percentage level for low battery notifications with us. Because this product feedback was already requested on this board, I’ve moved your post here. Please support this product feedback by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
I have a versa 4 and I get a low battery warning at 35% which actually is 2+days of use. Would like to adjust to 20% unless there’s a reason to not let battery charge go much lower.
I definitely agree that 35% battery is WAY too early to notify. I have a new Versa 4 and this really needs to be at 20% like it was on the past devices, or have the ability to set it where you want to be notified. Crazy how things go backwards and options get worse...
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
