Ability to disable automatic goal notification
It would be great if we were able to turn off/disable the vibration on the automatic goal notification.  It can be quite startling.  My heart just about stops almost everytime it happens.
Moderator Edit: Added Labels
127 Comments
SJQ
Jogger
I REALLY dislike having the automatic goal notification go off in the middle of a run. This has been a complaint for over seven years and has gotten no traction. Please put this extremely simple change in. If your programmer(s) are telling you that it is a complicated or time consuming change they are lying to you.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @SJQ, thank you for taking the time to share your feedback about the possibility of disabling the automatic goal notification for Fitbit devicesThis feature suggestion already exists, so I’ve moved your post herethis helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Thank you again for your participation in the Community.
