The 250 steps warning at 10 minutes prior to the hour end is excellent but I have found if you are engrossed in an issue you miss it because of the low intensity and similar to normal notifications. It isn't a normal notification.
At those hours where I feel I will have that situation I have set silent alarms on the 1/2 hour.
I feel the 250 step warning should be similar to the Silent Alarm intensity and possibly with the snooze option.
Added 2nd December 2016
Now that we have 10 Challenges the 10 minute before the hour vibrating warning is being "lost" withj all of the notifications.
Moderator edit: Labels
Colin:Victoria, Australia
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
