@lemos the option he is referring to is the ability to edit/categorize a recorded activity from within the Android app. Currently, you can edit it on the website/dashboard, and you can edit it in the iOS app, but not int the Android app.
I agree that this is needed for the Android App. I had to take the App off my Ipad because I kept having Sync issues when using both so decided to keep on phone (Samsung S5). Unfortunately now I have to go to dashboard to categorize workouts.
There is functionality in the IOS app that isn't in Android, the two should (where its not reliant on specific HW) have feature parity. The function in question is the ability to edit and/or re-categorise workouts that where started manually via my fitbit device
Hi @ECWsussex, thanks for explaining why you would like to have this option. I've moved it into a similar suggestion which has been updated as "Released". You can learn more about here. Keep adding your suggestions!
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
