I love my Ionic. Its the first fitness tracker that really works which ALSO has a music option but the functionality is a little frustrating.
Two features that would greatly improve the Ionic would be...
1) Drag and Drop uploads. Being able to plug my ionic into my Mac and drag playlists/podcasts across. Means I can still update watching with WIFI (especially as the WIFI sync seems time-consuming and glitchy - especially when uploading large files).
2) More player controls. Again, I largely listen to podcasts when running and being able to fast forward to a particular point in a track would be great. Especially as it would seem that Ionic doesn't remember where you last got up to so having to re-listen to the first hour of a 2 hours pod is a little frustrating.
These two functions would be a really strong addition to what is otherwise a great little device.
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
