Under "Cardio Load" there used to be a colored bar meant to indicate if you might be undertraining or overtraining. Due to yet another bug of some sort; this bar is now missing.
This is needed because:
Because you need to be aware of the problem so that you can fix it.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
