I'd like to see the weight goal presented as a  goal weight range.  My goal weight range is between 180 and 185 (I'm a six foot tall guy).  I don't want to set my goal weight at 185 because I think it will be too easy to forget that my range starts at 180.  So, I set it at 180, but through normal fluctuations for water and other factors, I almost never weigh 180 - though I'm within my acceptable (goal) weight range.  I'd like to see the goal weight presented as a range that can be set by the user (within some reasonable limitation).  Then users could be congratulated on maintaining their weight range, versus this "you've attained your goal weight X number of times!"  Small fluctuations in weight are normal and shouldn't been presented  in a negative light.  If that's already been suggested, I apologize for taking up the forum space.
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
