Hello guys,
Nowadays I'm wearing a Fitbit Charge HR and a Xiaomi Mi Band 1s (both have similar specifications). However there is one feature (about heart rate) that I like so much in Xiaomi but is missed in Fitbit.
On Xiaomi Mi Band 1s you can select and interval to monitor your heart rate, instead of a constant monitoring. For instance, you can set an interval of 5 minutes and your band measures your heart rate every 5 minutes. This is a good way in order to save battery, as you know the heart rate feature consumes a lot of battery.
My question is, would be possible to include this feature in the current "Heart Rate" Fitbit options? I mean some feature to specify an interval in order to measure your heart rate.
Current "Heart Rate" options are "Enabled, Disabled or Automatic". What I would like to see is an extra option like "Interval" to specify an interval (in minutes).
I'm sure this will almost double battery life and moreover you will get relevant data about your heart rate.
What do you think?
Regards!
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
