Hourly steps Widget on Dashboard
Could you add a feature to the online fitbit dashboard. I have a fitbit2. There is no screen to view status of hourly steps. I use the online browser version on the job. I'd like to see how many steps i've done or have remaining per hour on the specific per hour widget. Thank you for reading.
I read a post from 2016. Doesn't apply so I will add to original suggestion.
Moderator edit: Label
1 Comment
Status changed to: Existing Feature
LanuzaFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hello @HelloWrld.
You can already see your hourly goal on the web Dashboard. You should get a tile there where it shows.
If the tile is not showing up, check this article with instructions on how to add tiles that might be hidden at the moment.
Feel free to reach out with you have any questions.
