Integration with ACCU-CHEK
It would be great if Fitbit and ACCU-CHEK were compatible...then I could pull up just one report for the doc instead of having to go onto different apps
Moderator edit: Subject for clarity and labels.
1 Comment
Status changed to: Not currently planned
YojanaFitbit
Moderator Alum
Moderator Alum
Thanks for sharing this suggestion. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit! We’d encourage you to make your suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly! Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
