Integrations with Zero app
I use the Zero app to tracking fasting. I would love to have this kind of tracking incorporated into the Fitbit app. Or, failing that, at least be able to connect my Fitbit app with the Zero app so I don't have to enter weight, sleep, etc into the Zero APP.
1 Comment
Status changed to: Not currently planned
YojanaFitbit
Moderator Alum
Moderator Alum
Thanks for sharing this suggestion. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly.
You can also check this other suggestion: Intermittent Fasting tracker
Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
