OK, so after my Fitbit device stated I walked over 20,000 steps in a day, I was anxiously awaiting my badge. When I did not receive it, I contacted the support team to see what was up with that and I found out some disheartening info!
When logging an activity during the time you were actually doing it, you will be overwriting any data recorded. New data will be created, and the new data does NOT go towards badges. Fitbit stated that there are different variables in activities that will alter your steps. I don’t see how. Steps are steps. They may be talking about calories burned, but that’s not the issue. When overwriting, their “formulas” not only overwrite, but give you a false number of steps taken, for better or worse due to these variables. Though, Fitbit stated that it would not create false steps.
It does.
Believing them, I started logging my activity at 3am as I did not want actual data overwritten. I wanted all my steps to go towards badges. So what do I find out?? Logging activity at 3am gave me an additional 5,000 FALSE STEPS. That needs to stop.
I purchased this device to ACCURATELY track my sleep, my steps & time put into activity and it seems you can’t log one without having other data falsified. Fitbit suggested I create a “suggestion” here and if it gets enough “likes” the developers will consider fixing this problem. So there you go. In the meantime I will be researching other products that don’t overwrite and/or create false data.
BTW, this is also a problem if you’re competing with other Fitbit users in regards to how many steps are taken over a certain period of time as clearly the data can be faked…and if there’s money involved to the winner, that’s problematic. So Fitbit, you should REALLY consider fixing this. Allow people to record the activity WITHOUT it affecting the number of steps actually taken. Simple.
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
