Make Heart Rate Data export in Excel/CSV format
Please add the heart rate data to the reports that can be downloaded/exported.  The ones for the activity and sleep are perfect but since I have a pacemaker I really need to have one to print out for my cardiologist showing how often I rise above the set pace.
Thank you
Mod edit: Title
903 Comments
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @TheLeroyMan! Thanks for sharing this great suggestion about allowing the option to export heart rate data with us. I've moved it into a similar request. You can also check this other suggestion, post a comment or click on the thumbs-up to show your support.
jraper
First Steps
What is Fitbit's policy on reviewing suggested changes?  That is, how long does a suggestion have to be posted and voted on before Fitbit will considering implementing a change? Or deciding that the suggestion is one that they will not consider doing at all?
I would like to stay with Fitbit, but if you will not consider adding this feature, then I will switch to another optical heart rate monitor that will.  Currently I'm considering the Polar OH1 or Scoshce Rhythm Plus, which allows the user to export their minute-by-minute heart rate data, instead of providing the user with an average heart rate over a 5 minute interval.
mtyger
First Steps
I wish I knew... I don’t see why we have to vote on anything at all. Fitbit should just change it... the end.
AukeL
Runner
No, you’re not the only one indeed. And with some Python code it is easy.
Moderator edit: removed personal information
mtyger
First Steps
I’ve already moved on to Apple Watch
Sent from Michele Ki**ahem**a's iPhone
AnneChung
First Steps
I totally agree. It was my being able to monitor my health via a LifeTrack
device that helped me have discussions with my doctor, use less medications
and eventually no medications. This was a savings in time and
money.....all due to that data.
TrendyTreky
First Steps
So far I've only seen the 5 minute data available by downloading your entire history.
AukeL
Runner
Yeah you’re right. But some people complain already for years and don’t solve the issue. But contrary to an apple watch Fitbit allows you to download all 8640 HR measurement points personally on a daily basis.
Dr_C
Jogger
?my data?
Dr_C
Jogger
My fitbit battery is on the edge of doing so I will not be purchasing another.
TrendyTreky
First Steps
Status changed to: Under Consideration
LizFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
This information is currently available for export in the complete Account Archive export which is in JSON format (see our help article here).
If you would like this information presented differently, or in a different format, please vote on:
SunsetRunner
Not applicable
The data must be there so any decent developer could quickly run up an export facility, at least for the coarse granularity (5 minute slots). As I'm recovering from heart surgery it would be extremely useful.
ehoffmann
First Steps
FULL export of collected heart rate data is literally the ONLY piece of data I want exported.  This was the entire point of purchasing the watch
AukeL
Runner
And it is so easy to do. Fitbit does make this option available and you need to write some code for it. But it is not that hard...
Regards,
SunsetRunner
Not applicable
Yes... someone with decent Python skills could probably write a bit of code to do it automatically. The data can be got from "inspect element" and is given as a set of chart coordinates. Using these (and a couple of extra pieces of data in the element) it can be converted to heartrate and time, actually three samples per five minutes so a better granularity than displayed. If anyone fancies taking this forward I'd be happy to help!
AukeL
Runner
Yes indeed. We built a database some years ago already and review the fitbit tracker data with Python code. Very interesting to have also AI investigating HR and HRV patterns. It is all possible.
Regards,
ldhiker
Jogger
This was resolved in 2017. Google for "Pulse Watch" github. The relevant community link is https://community.fitbit.com/t5/Fitbit-com-Dashboard/Download-heartrate-data/td-p/1735843 best answer. You cannot just search for "pulse watch" github directly in the forum because the advance search on strings in quotes does not work.
SunsetRunner
Not applicable
@ldhiker Nice to see there's a third-party facility, however the feature suggestion is for Fitbit to provide it natively. You'd think, if ordinary mortals (users) can run up tools, it would be easy for Fitbit to do so. The existing data export really lets the app/website down - it's little more than a summary. A great pity!
AukeL
Runner
Yeah, right. But it is not the case unfortunately. So we can either keep complaining or solve it. I decided to solve it.
Regards,
Cyndy73
Recovery Runner
I agree, Please add heart rate data to the reports that can be downloaded/exported.
I need to print this out for my Dr and there isn't anyway to do so. Thank you
AukeL
Runner
Yes, indeed it is possible. If you need any help you can leave me a post.
Regards,
SunsetRunner
Not applicable
Three years and they still won't let us download all of our data, especially heart rate, in a useful format (CSV or Excel).  What a shame.  Now that Google is taking over I will be terminating my relationship with FitBit as I don't want anymore of my data consolidated in one place.  It is too bad I won't be able to download all of MY personal data before I go.
TrendyTreky
First Steps
Perform a full download of your data before you discontinue.  (See prior messages on this)JSON format can be read by some more recent versions of Excel
Status changed to: Not currently planned
LizFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi everyone, and thanks so much for sharing this suggestion. Heart rate is currently available through export up to 31 days of your recent Fitbit data, or an archive of your Fitbit data for the lifetime of your account. For more information on data export, see our help article here.
While we don’t currently have plans to release this export in Excel or CSV format, it is available in JSON. Heart rate data and trends are also available in our new Wellness Report, under our Fitbit Premium subscription, so they are easily shareable with your medical practitioner.
We always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visit our FAQsWe're always striving to enhance Fitbit products and services, and your input is a big part of that process. We truly thank you for taking the time to share your feedback with us.
