There should be a way to switch between using a fitbit tracker and using your smartphone/iPhone when the tracker's battery is low like other trackers (Zeroner, etc...).
Hi @MikeJJU, and thanks for taking the time to share your suggestion about adding an option to switch between a Fitbit Tracker and a smartphone with us!
If your cellphone comes with a chip inside (M7/M8) compatible to connect with MobileTrack, you should be able to use it to track your steps, distance, and calories burned. It does not track floors, sleep, active minutes nor activities. To verify if your phone offers this option, please go to this link and look for the following message:
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
