We are experiencing extremely high contact volume right now and estimated wait times will be higher than normal. We appreciate your patience and understanding as we work to provide support as quickly as possible. In the meantime, please visit our Help Center for troubleshooting articles and our Community Forums.
I would like the implementation of multiple recurrent countdown timers. It includes the ability to set up to 2-3 countdown timers. The ability to set recurrent timers on a stoppable loop.
Hi @OptimizeOli - On Versa and Sense watches have you tried the SimpleTimer app - this gives you one timer with many options, a later version will give you more. Works well in background with SimpleClockPro, otherwise 3rd party apps aren't allowed to use system background mode.
Thank you for the comment. That would be fantastic if I had the Sense or the Versa. I have the Charge HR 4, would there be any way to have multiple countdown timers otherwise I will have to upgrade to later models. I just wanted the ability to be able to have a recurrent timer to move from different exercises. E.g. A timer that repeats in small intervals. So 2:30 timer for squats then goes off to prompt you to change to 2:30 of walking.
That wouldn't work in your case as you can only run one app at a time, exercise or timer and you would need the system timer you are requesting to achieve what you want even on later models.
Hi @OptimizeOli, and thanks for taking the time to share this suggestion about adding multiple countdown timers for Charge 4. While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
We're always striving to enhance Fitbit products and services, and your input is a big part of that process. We truly thank you for taking the time to share your feedback with us.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
