Some people enjoy running laps. They try to achieve their goal by running a set amount of laps. Generally these laps are usually 200 - 400 metres in diameter and are oval in length. Let's mix it up.
It would be nice if Fitbit would incorporate a dozen or more actual NASCAR tracks and F-One circuits to run on.
These tracks vary in distance, generally from 1 to 8 kilometres and come in all different shapes. I'm thinking running on these laps would be a little more enjoyable, and different.
Also, if your smartphone would track your progress in real-time, the experience would be that much better. Simply select your track, and away you go. These tracks can also be utilized into a challenge or adventure as well. Below is an example of various Formula One circuits.
For your consideration.
Moderator edit: labels
MICHAEL | ONTARIO, CANADA
Charge HR, Charge 2, Aria - iOS, Windows 10
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
