It would be great to add option to define stride lenghts at different speeds. For example I did calculations based on a treadmill and the results are:
5 km/h ......... 70 cm
8,5 km/h ....... 84 cm
9,2 km/h ....... 91 cm
10 km/h ........ 98 cm
12 km/h ........ 117 cm
so it is hard to define "running stride length" as it varies significantly with speed.
Moderator edit: Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
