Sync CARROT Fit & CARROT Hunger apps with Fitbit
http://meetcarrot.com/index.html
I would like to synchronize my Fitbit data with CARROT Fit & CARROT Hunger apps. The link is above to review these apps.
Thank you so much for your time and consideration!
2 Comments
Status changed to: Existing Feature
EdsonFitbit
Fitbit Moderator
Fitbit Moderator
@SweetSal Thanks for your suggestion and for the link.
Currently you can link Fitbit with CARROT and synchronize your steps. You can link your accounts by following the next steps:
Tap on the top-left CARROT menu button, go to Settings and tap on the Link Fitbit button.
SweetSal
First Steps
@EdsonFitbit Thank you for your suggestion. However, the apps I am referring to are CARROT Fit and CARROT Hunger developed by Grailr LLC. I believe the app that you referenced is CARROT Wellness developed by Marvel Apps LLC. They are two different companies.
