01-04-2018 11:25 - edited 01-04-2018 11:25
Hello developer community. I require a bit of assistance. As the tutorials are still , shall we say a little lacking' for new developer wannabes like myself I was wondering whether someone could point me in the right direction.
I currently have a battery percentage on my watch face, now, how would I go about creating the function that would change the colour of the text when the battery reaches a certain percentage. I would also assume the same method would work for goal percentages.
I have tried certain methods but am worried my constant trial and error could end up damaging my ionic (as i already spent two hours sorting it out as it went on constant reboot, hence, why an emulated ionic is essential as the watch is not cheap).
Any tips would be much appreciated, thanks in advance.
Best Answer01-04-2018 19:06
01-04-2018 19:06
You can write a function calculateBatteryColor(percent) that takes the percentage returned from battery.chargeLevel:
var batteryLevel = battery.chargeLevel;
//console.log(`battery level: ${batteryLevel}%`);
batteryPercent.style.fill = calculateBatteryColor(Math.floor(batteryLevel));
batteryPercent.text = batteryLevel + "%";
/** @function
* @name calculateBatteryColor(percent)
* @Param percent { Number } Number percentage
* @return color { String } String color name
* Calculate the color of the battery circle
function calculateBatteryColor(percent) {
let color;
if (percent > 50) {
color = 'fb-green';
} else if (percent < 50 > 20) {
color = 'fb-yellow';
} else {
color = 'fb-red';
//console.log("battery color: " + color)
return color;
01-04-2018 19:06
01-04-2018 19:06
/** @function
let color;
if (percent > 50) {
color = 'fb-green';
} else {
color = 'fb-red';
return color;
01-05-2018 05:30
01-05-2018 05:30
if (percent > 50) {
color = 'fb-green';
} else {
color = 'fb-red';
}better:
if (percent > 50) {
color = 'fb-green';
} else if (percent > 20) {
} else {
color = 'fb-red';
}Because on 50% it would shown red.
And it's better to reduce/optimize the code 😉
But best is:
color = (percent>50) ? 'fb-green' : ((percent>20) ? 'fb-yellow' : 'fb-red');
01-05-2018 14:38
01-05-2018 14:38
Cheers guys, a combination these codes worked brilliantly. Much appreciated.
Best Answer01-12-2018 12:24
01-12-2018 12:24
Is there some sort of import that needs to happen on the index.js file for the battery to show on the watchface? I am not finding anything on it in the documentation I am looking at.
Best Answer01-12-2018 15:31
01-12-2018 15:31
import { battery } from "power"; console.log(Math.floor(battery.chargeLevel) + "%");
More information about the Power module can be found at: https://dev.fitbit.com/build/reference/device-api/power/
01-15-2018 04:51
01-15-2018 04:51
But best is: color = (percent>50) ? 'fb-green' : ((percent>20) ? 'fb-yellow' : 'fb-red');
I'd argue you definition of "best". That will compile to the same/similar execution as the if/else version but the if/else is significantly more readable. Readable code is a good thing to practice!
01-18-2018 07:20
01-18-2018 07:20
This solution works for coloring the text, however the percentage on the watchface does not update as the battery level decreases.
I attempted to put the below code in to the calculateBatteryColor(percent) function and call it with a display.onchange but it put my watch into a boot loop mode so don't do that....
let batteryPercent = document.getElementById("batteryPercent");
Creating its own function does not work either. what is the "best way" to keep the percentage updated. Bonus points if we can translate it into having it be a fill to a battery icon.
Best Answer01-18-2018 15:53
01-18-2018 15:53
Put the battery update code in a function, ie. updateBattery() and then call
updateBattery();
setInterval(updateBattery, 300000);
You call function when the app is first opened, and then at intervals with setInterval. The first parameter is the function name you want to set the interval on and the second is the interval in milliseconds that you want it to run on.
https://dev.fitbit.com/build/reference/companion-api/globals/#function-setinterval-
Best Answer05-23-2019 19:35
05-23-2019 19:35
Is there any way to do this to the background?
Best Answer05-25-2019 08:47
05-25-2019 08:47
I would think that this could be done with the background. You would just need to change the fill color using the same statement.
Best Answer03-23-2020 15:50
03-23-2020 15:50
Makes sense, thanks!
Best Answer04-23-2020 06:11
04-23-2020 06:11
Where would you put this statement in the fitbit studio? And how would you make it known that this is only to change the battery colour and none of the other styles?
