Tried everything.
All the simulator says is "DANG Simulator fails to start "
And Studio says:
App msg queue full, see https://dev.fitbit.com/kb/message-queue-full for recommendations.
Only Versa is affected. the others (Ionic, Versa Lite, Versa) run (almost) perfectly.
Even re-installing the simulator had no effect (Windows10)
Your clock or app is doing too much, blocking the event loop for too long. This causes the app/simulator to crash as you can see. You'll need to debug your code to see where you're blocking for too long, and chunk that work down using setTimeout.
Best AnswerThank you. This does not work for me, although it does for others. I have a laptop (Windows 10) and the simulator works there. The simulator does not work on my Windows 10 desktop (will try on others). Tired reinstalling, rebooting, etc. I can't get much from the log except a bunch of retries and fails. Just for information, here are the final entries showing that something is not responding:
[2020-02-05 18:17:15.897] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:17:18.396] [warn] 1 retries left: MethodCallTimeout: No response received for RPC call to 'initialize'
[2020-02-05 18:17:28.403] [info] shell->app: {"id":0,"method":"initialize","params":{"capabilities":{"protocol":{"maxMessageSize":536870912}}},"jsonrpc":"2.0"}
[2020-02-05 18:17:30.904] [error] Simulator hosts failed to start: MethodCallTimeout: No response received for RPC call to 'initialize'
Let me elaborate a bit more:
I deleted the whole directory C:\Users\%user%\AppData\Roaming\Fitbit OS Simulator.
In my case c:\gebruikers\mario\AppData\Roaming\Fitbit OS Simulator. 🙂
I did not reinstall,or delete the application itself.
I also found out that I get a lot of errors when the laptop is very slow, or when the internet connection is bad.
Let me ask you: does the simulator not start up at all? Not even with the logo shining?
does nothing work on the simulator, on any type of device? Can you switch to another device, like Versa 2?
