It would be nice if the Fitbit OS simulator allowed adjusting the default location.
Currently each time I launch the simulator the default location is set to Munich, Germany and I have to then utilize the map to adjust the location to what I actually want it to be.
An alternative solution would be to save the last adjusted to location and use that as the startup location upon relaunching the simulator at a later point.
