Accelerometer Readout Timestamps (Fitbit Ionic)
ANSWERED
Hey everyone,
I am using the accelerometer API and I encountered a problem with the timestamps. I use this chunk
acc.addEventListener("reading", () => {
    for (let index = 0; index < acc.readings.timestamp.length; index++) {
      console.log(acc.readings.timestamp[index])})
to read the stamps. The resulting outputs in the console are 6 to 7 digit numbers. My experiments suggest that these numbers correspond to the milliseconds past since some event I don't know.
Do you know how to properly interpret these and how to convert them to a regular 12 digit (ms) UNIX timestamps?
Best
Simon
1 BEST ANSWER
Accepted Solutions
You'd need your own timestamp, the one in the sensor is:
Timestamp of the reading in milliseconds.
NOTE: this is relative to an unspecified arbitrary 0 time, or null if no reading is available (when the sensor is not yet activated and there are no valid cached values that can be used).
3 REPLIES 3
Hey Jon,
thanks so much for your fast reply. I think it would be incredibly useful to automatically have UNIX timestamps in the actual sensor readout.
Best
Simon
What's the point of this timestamp then? If we cannot use it?
