Hi,
I'm having issues with my clockface where it keeps restarting. Is it possible to access clockface logs on my Versa? The clockface is installed through the Fitbit gallery.
I have a test clockface that I run on my device through Fitbit Studio with the same code but it's difficult to replicate the issue - the issue seems to happen after a few hours.
I'm using an Android device.
Thanks,
Jamie
That's a tough one. We don't provide device logs like that. Perhaps you could add a debug text layer to the clock and log the memory usage to see if you have a leak somewhere.
import { memory } from "system";
console.log("JS memory: " + memory.js.used + "/" + memory.js.total);
Best AnswerHey Jon,
I have a feeling it's memory related, and actually had the thought of adding an element to the screen that shows memory usage after posting this - great minds!
Thanks for your reply.
