10-01-2020 18:44 - edited 10-01-2020 18:56
So I tried to submit my app update to fitbit, but they replied with this message:
Due to the fact that your CLOCK has functionality issues, we regretfully inform you that we have declined your submission.
Please find the issues uncovered during testing below:
# if you want to use the AZM function, you need to change the icon from your design (currently you use the AM icon).
Please consult the following link for more information: https://dev.fitbit.com/legal/app-gallery-guidelines/
However, I can't find where to download the AZM icon. When I go to the downloadable assets page, it just redirects to here https://dev.fitbit.com/build/guides/design-guidelines/.
Any help?
Edit: Nevermind, I found the assets on github. If anyone else needs help, here they are: https://github.com/Fitbit/sdk-design-assets
10-01-2020 19:34
10-01-2020 19:34
I think it might be in here.
Best Answer10-05-2020 01:03
10-05-2020 01:03
Be sure to convert them to 8 bit greyscale or they don't work properly
