Hello dev world. I have a watch face running a couple of animations. I use the function to delay the animation time. The trouble is I want this animation to happen every time the watch face comes on. I get the feeling currently that the animation is always running no matter what ( if i have it on infinite) which in turn i would assume would have an affect on the battery.
I have tried different things in terms of enable etc but none of these seem to activate when the screen comes on and runs everything else.
Now, it works when i use the click as the begin point but so is there something simple I am missing or do i just have run with it and play around with the animation setting to limit the drain on the battery.
Thanks in advance.
import { display } from "display";
display.addEventListener("change", function() {
if (display.on) {
wake();
} else {
sleep();
function wake() {
// do something when the screen wakes
// https://dev.fitbit.com/build/guides/user-interface/animations/#javascript-animations
myinstance.animate("enable"); // Specify the name of the event to trigger
function sleep() {
// do something when the screen sleeps
if (display.on) {
wake();
} else {
sleep();
function wake() {
function sleep() {
