Hi,
I just created an analog clock for my versa, quite simple, but everything works. Except the background, it doesn't load.
I followed the tutorial @ozibyte (a big thank you for your tutorial), but the wallpaper stay black.
Do you know why?
Sorry for google translate^^
Best AnswerWithout looking at the code I can't say for certain, but it sounds like the path to the backgound image is wrong.
Best AnswerWhat do you need, index.js ou index.gui, or both ?
Best Answerindex.gui I expect.
In your index.gui (or index.js) do you have the path "C:/users/..." mentioned?
Best AnswerIt can go either place.
The path is a relative path from the root of the app install. The c:\... message let's us know you are the simulator. The path should be something like "./path/to/file.png". Where are you saving the file to?
Best AnswerI haven't been following this closely, but it sounds to me like there might be confusion between where an image is stored on the development computer (which could start with 'c:\users') and where an image is stored on the watch (simulator or real) (which would typically start with '/resources/' or one of the folders listed on the LHS of the IDE).
Best Answeri just drag te file into 'resources' folder and i have no path mentionned in my index.
my index.gui :
<svg class="background">
<defs>
<section>
<symbol id="sec-hand">
<line x1="0" y1="0" x2="0" y2="130" stroke-width="2"/>
</symbol>
<symbol id="min-hand">
<line x1="0" y1="0" x2="0" y2="130" stroke-width="4"/>
</symbol>
<symbol id="hour-hand">
<line x1="0" y1="0" x2="0" y2="80" stroke-width="6"/>
</symbol>
<symbol id="center-dot">
<circle r="4" fill="#F5F5F5"/>
<circle r="2" fill="fb-dark-gray"/>
</symbol>
</section>
<symbol id="clock-widget" class='clock-widget' type='clock-widget'
focusable='false' pointer-events='visible' system-events='all' width='300' height='300' data-size='16'/>
</defs>
<image id="WatchFace" class="WatchFace" href="background.png" />
<text id="date1" class="date1" />
<text id="date2" class="date2" />
<use id="analog-watch-hands" href='#clock-widget' x='0' y='0' >
<g transform="translate(50%,50%)">
<g id="second-hand">
<use href="#sec-hand" class="sec-hand" />
</g>
<g id="minute-hand">
<use href="#min-hand" class="min-hand" />
</g>
<g id="hour-hand">
<use href="#hour-hand" class="hour-hand" />
</g>
<g id="dot">
<use href="#center-dot" class="center-dot" />
</g>
</g>
</use>
Best AnswerThis
Should be
href="./resources/background.png"
You should also load images with sync.
Best AnswerHi
Hopefully, I'm not hijacking this thread; but I have the exact same issue (except, no path error), from the same source: https://ozibyte.com/creating-an-analog-fitbit-ionic-clockface-part-1/
Same problem whether using simulator or versa.
Everything displays and works, except for the backgound.png.
Best AnswerHi
To answer my own post: the problem was with the downloaded background.png. I opened it, then saved it without transparency and that seemed to do the trick.
Thanks all.
