The update process went like a dream. No problems and nice and quick. Good job fitbit. Ionic seems more responsive somehow.
However, an app that installed ok before now gives the following error:
This only happens on first install. If you run the app from the Ionic (install has completed), everything works fine. Is this an issue that needs adding to a list?
Hi @JonFitbit,
I will update github with the current source. It only happens on install but does work fine. Will post up once update which is likely going to be tomorrow.
The project is on github: https://github.com/non-runner-rob/runmaster
Also, it installs fine from the gam link, doesn't run first time but does second and subsequent times.
Best Answer@SunsetRunner Quick question about your runmaster app...
I was wondering if you could tell me which part of your code is handling the communication to the companion app and to the cloud? I'm trying to do something similar on one of my projects.
Thanks in advance for the help!
